enky utente attivo
Iscritto: 30 Gen 2012 Messaggi: 1164 Località: Brixia
Inviato: Gio 05 Set, 2013 7:56 am Oggetto: |
Press-releases
German Press Release (via systemkamera-forum) here (tranlsation). They say the lens will be available in Europe for €899 starting from the beginning of October.
Fujifilm GLOBAL press release!
FUJIFILM Corporation (President: Shigehiro Nakajima) is proud to announce the launch of the FUJINON XF23mmF1.4 R lens for Fujifilm compact system cameras.
FUJINON XF lenses represent the pinnacle of Fujifilm’s optical design technology, with top quality all-glass construction which includes an aspherical lens element. Their fast maximum apertures increase versatility for low-light photography and create scenes with a beautiful bokeh effect, while Fujifilm’s HT-EBC coating reduces reflections over a wider range of wavelengths, thereby controlling flare and ghosting. These advanced optical engineering techniques combine to deliver full-frame sensor resolution and noise level performance in the highly detailed APS-C sized X-Trans CMOS sensor in Fujifilm X-mount cameras.
With a focal length equivalent to 35mm in the 35mm format, the FUJINON XF23mmF1.4 R is suitable for a wide range of applications including portraits and landscapes as well as more general photography. The fast maximum aperture of f/1.4 allows you to shoot hand-held in low light conditions, where zoom lenses would introduce camera shake, plus it creates beautiful bokeh for artistic images.
• Dedicated lens design for use with Fujifilm X-Trans CMOS sensors
The new lens design provides enhanced resolving power with high contrast to draw the maximum performance out of the highly descriptive X-Trans CMOS sensor.
The fast f/1.4 aperture allows the user to create images with beautiful bokeh and helps reduce blurring in low light conditions.
Lens distortion has been reduced to the absolute minimum using only optical rather than digital correction, thereby delivering the highest possible picture quality.
The rounded seven-blade diaphragm ensures smooth bokeh even when shooting portraits or product shots at a medium aperture to maintain reasonable depth-of-field.
All lens elements are treated with Fujifilm’s multilayer HT-EBC (High Transmittance Electron Beam Coating) which delivers enhanced durability and ensures an even spread of light across the sensor.
• Ideal focal length for day to day shooting
The versatile focal length equivalent to 35mm in the 35mm format means you can enjoy both a wide-angle and telephoto approach by using your own feet to adjust the distance or angle with the subject matter.
• Distance indicator suitable for quick shots
The FUJINON XF23mmF1.4 R features a camera-to-subject distance indicator and a depth-of-field scale on the barrel. Both are useful when manually pre-focusing to capture a fast moving subject, or minimize the shutter lag to capture a fleeting moment.
The minimum working distance of around 28cm also makes this lens ideal for close-up shots.
• High speed autofocus
The lens uses an internal focusing system for high speed autofocus. The focusing lens group consists of three cemented lens elements and one aspheric lens element to keep weight down while the built-in high-torque DC coreless motor delivers ultra-fast AF performance.
• Compact size and premium design
The FUJINON XF23mmF1.4 R weighs 300g and measures just 63mm in length making it the most compact and lightweight lens of its class.
Metal parts are used for the focus and aperture rings, which are designed to give just the right amount of torque and feel in use.
The large front element gives the premium look of a fast lens, reminiscent of classic lenses from the past. _________________ Luca
Nikon D600 | Fuji X100s
http://www.flickr.com/photos/lucascalmati/ |
Marco Bozzato utente attivo
Iscritto: 14 Mar 2009 Messaggi: 1742 Località: Roma
Tirpitz utente attivo
Iscritto: 30 Giu 2011 Messaggi: 961
Inviato: Gio 05 Set, 2013 8:19 am Oggetto: |
| cicquetto ha scritto: | un attimo, il prezzo dovrebbe essere 850$, meno di 650€ quindi, non faranno il cambio 1:1 ma qualcosa giu di li si credo (e spero)
300g, più del 14 purtroppo. |
Rimonta l'IVA e qualche dazietto doganale e vedrai che torni agevolmente in area 800-850 (che è quello a cui immagino si troverà street).
Pesa più o meno come lo zoometto (anche in lunghezza siamo lì), non esattamente una piuma in effetti.. |
Giovanni.Santangelo utente attivo
Iscritto: 17 Gen 2006 Messaggi: 1870 Località: Airola (BN)
Inviato: Gio 05 Set, 2013 9:33 am Oggetto: |
| Roomby ha scritto: | Ti dirò...sono tecnicismi che non mi appartengono. E non me ne può fregare di meno. Ciò che mi importa è che sarà l'equivalente di un medio tele da ritratto luminoso e, spero vivissimamente, di ottima resa...speriamo proprio. Sarà tutto da verificare.
Poi...le conversioni in realtà nella mia testa si fermano giusto dai 3 ai 4 secondi...
Umby |
Più che tecnicismi mi sembrano affermazioni abbastanza aleatorie quelle sulla corrispondenza aritmetica tra apertura e PDC in relazione alla lunghezza focale (visto che il formato non c'entra nulla).
La PDC è una grandezza basata su parametri convenzionali, come tale si presta a confronti ma non a misurazione sottoposte a leggi aritmetiche. _________________ "Less is more"
(Ludwig Mies van der Rohe) |
Donagh utente attivo
Iscritto: 16 Lug 2004 Messaggi: 2116 Località: TRENTINO, Riva Del Garda
robysalo utente
Iscritto: 03 Mgg 2007 Messaggi: 408 Località: Torino
Inviato: Gio 05 Set, 2013 1:25 pm Oggetto: |
Lente interessante, non fosse per il prezzo che IMHO trova poche giusticazioni. Una lente che max poteva stare sui 600 euro di street-price.
Credo che ora che Fuji ha iniziato ad avere un parco abbastanza ampio di clienti stia cominciando a stringere il cappio al collo con i prezzi delle lenti.
Peccato.... _________________ Pentax K5IIS Sony A7II
Pentax SMC HD 15mm f/4 limited, Pentax SMC HD 21mm f/3.2 limited, Pentax SMC 35mm f/2.4, Pentax SMC 50mm f/1.8, Pentax SMC 70mm f/2.4 limited, Pentax SMC A 28mm f/2.8, Pentax SMC M 135mm f/3.5 Jupiter 37A 135mm f/3.5 , Jupiter 9 85mm f/2 , Helios 44M 58mm f/2, Zeiss FE 16-35mm f/4, Zeiss FE 55mm f/1.8, Sony FE 28-70mm |
Inviato: Gio 05 Set, 2013 1:43 pm Oggetto: |
Il paragone con CaNikon (quello con gli universali non m'interessa) è, a parere puramente personale, leggermente forzato.
Altra filosofia, altre tirature, parametri che chi si accosta ad un marchio come Fuji dovrebbe avere presenti.
Un 35 1,4 Nikon o Canon costa molto di più, un 2,0 meno ma, ed è un approccio che non condivido, al minor prezzo dovuto alla minor luminosità corrisponde anche un calo vistoso della qualità costruttiva.
Preferisco, l'approccio in stile Leica che adotta Fuji, dove pago solo la maggiore luminosità e basta, ed il vetro ottico, cosi come i barilotti in metallo, pesano e costano. _________________ "Less is more"
Bio981 utente attivo
Iscritto: 21 Set 2005 Messaggi: 2542 Località: Aosta
Inviato: Gio 05 Set, 2013 5:08 pm Oggetto: |
io dico solo una cosa
vediamolo in azione prima di giudicare il prezzo  |
Inviato: Ven 06 Set, 2013 8:52 am Oggetto: |
I primi samples del sito Fuji non è che facciano proprio gridare al miracolo, ma come già successo in passato per altre ottiche, non sono certo un test molto attendibile...
Aspettiamo i primi test "seri".. |
enky utente attivo
Roomby utente attivo
Iscritto: 15 Mgg 2012 Messaggi: 590 Località: Negrar (VR)
Inviato: Ven 06 Set, 2013 10:31 pm Oggetto: |
Le ho viste anch'io e direi proprio che non sono per nulla male. Una lente veramente interessante...
Sì d'accordo...non è pancake, non è propriamente compatta, ma mi piace parecchio...
Umby |
xanakinx utente
Iscritto: 23 Giu 2010 Messaggi: 62
Inviato: Ven 06 Set, 2013 11:02 pm Oggetto: |
| 850€ è un prezzo molto elevato secondo me, se si considera che a poco più si prende una x100s, con apertura f2, che magari risulta anche più corta del solo obiettivo in questione... |
Inviato: Ven 06 Set, 2013 11:19 pm Oggetto: |
Osservazione ineccepibile, ma va considerato anche che ci può essere chi apprezza l'approccio all'immagine offerto da un apparecchio a mirino galileiano come la X1 indipendentemente da considerazioni dimensionali, tanto più ora che la presenza ANCHE di display e/o mirini elettronici (ibridi) ne rimuove i limiti. _________________ "Less is more"
Blackmamb4 utente
Iscritto: 17 Gen 2009 Messaggi: 115
Inviato: Dom 10 Nov, 2013 1:21 pm Oggetto: |
| raqgazzi buon giorno a tutti , nessuno che l'ha comprato ??? |
Manuel C. utente attivo
Iscritto: 01 Mgg 2005 Messaggi: 2128 Località: friuli
Inviato: Dom 10 Nov, 2013 2:21 pm Oggetto: |
In un forum fuji, ci sono alcuni utenti che lo hanno ordinato, prezzo dai 750 ai 790  |
Blackmamb4 utente
Inviato: Gio 14 Nov, 2013 6:28 pm Oggetto: |
quindi ancora nessuno ne è in possesso.
Attenderemo con ansia i primi test  |
Havier utente
Iscritto: 07 Ott 2007 Messaggi: 91
Inviato: Dom 24 Nov, 2013 9:35 pm Oggetto: |
| Anche sul forum fuji ci sono i primi esempi dei fortunati possessori. |
Inviato: Dom 24 Nov, 2013 11:58 pm Oggetto: |
Non mi aspettavo nulla di meno, pare che Fuji abbia di nuovo fatto centro.
Potendo l'unico dubbio che avrei, visto il prezzo peraltro commisurato alla qualità, è valutare, come ho già detto dove si parlava della X-E2, se non convenga prendere quello "attaccato" alla 100S.
Quest'ultima soluzione ha dalla sua il fatto di consentire di disporre di un'altro corpo con mirino ottico, il tutto molto compatto. Viceversa il nuovo 1,4 ha uno stop in più e "seguirà" l'inevitabile evoluzione del sensore su altri corpi.
Null'altro che considerazioni ad alta voce. _________________ "Less is more"
Pasi moderatore
Iscritto: 15 Dic 2007 Messaggi: 11395 Località: Romagna
