Canon annuncia 18-55 f/3.5-5.6 IS versione II
xrr
Iscritto: 08 Apr 2006
MessaggioInviato: Lun 07 Feb, 2011 9:29 am    Oggetto: Canon annuncia 18-55 f/3.5-5.6 IS versione II Rispondi con citazione
Introducing the new EF-S 18-55mm f/3.5-5.6 IS II
Launching with the EOS 600D is the EF-S 18-55mm f/3.5-5.6 IS II – a new kit lens that provides excellent performance for beginners. A lightweight construction makes it easy to carry, and Canon’s acclaimed optical Image Stabilization also minimises the risk of blur, allowing photographers to use shutter speeds 4 stops slower while still maintaining a blur-free shot. The EF-S 18-55mm f/3.5-5.6 IS II will succeed the existing EF-S 18-55mm f/3.5-5.6 IS in Canon’s lens line-up.
Esempi foto:
http://www.dpreview.com/galleries/reviewsamples/albums/canon-eos-600d-preview-samples/
http://www.dpreview.com/galleries/reviewsamples/albums/canon-eos-1100d-preview-samples
Canon EOS 40D - EF-S 17-85 IS - Canon DIGITAL IXUS 80 IS - Monitor Professionale Lacie 22" - Monitor prosumer Asus LCD ad alti DPI
MessaggioInviato: Lun 07 Feb, 2011 11:01 am    Oggetto: Rispondi con citazione
E non è l'unica, secondo dpreview hanno tirato fuori anche un upgrade della versione non stabilizzata:
the 1100D will also be offered with a more significantly updated version of the non-stabilized lens. The EF-S 18-55mm F3.5-5.6 III receives the same optical design as seen in the IS versions, which should result in a significant improvement in image quality over its predecessors.
In pratica entrambi condividono lo stesso progetto ottico, ma non la stabilizzazione.
Certo che ora sarà ancor più facile fare confusione! LOL
