ranton utente attivo
Inviato: Mer 14 Feb, 2018 10:22 am Oggetto: Panasonic annuncia il primo global shutter da 36MP |
Panasonic Announces 8K High-Resolution, High-Performance Global Shutter.
Dopo tanti anni di attesa è stato finalmente annunciato il primo rivoluzionario Sensore con Global Shutter in grado di sfornare immagini 8K (36 MP) a 60 fps, catturate nello stesso istante da ogni pixel. Speriamo di vederlo presto sulla GH6:
Citazione: | Panasonic has announced the world's first 8K high-resolution global shutter technology. This can capture 36 megapixel images at 60fps using a CMOS image sensor with an Organic Photoconductive Film (OPF). Utilizing the global shutter function that enables simultaneous image capture by all pixels, Panasonic expect to be able to capture moving objects instantaneously without distortion. |
Citazione: | The new technology has the following advantages.
- 8K resolution, 60fps framerate, 450k saturation electrons and global shutter function are realized simultaneously.
- Switching between high sensitivity mode and high saturation mode is possible using gain switching function.
- The ND filter function can be realized steplessly by controlling the voltage applied to the OPF. |
 _________________ https://www.flickr.com/photos/ranton/ |
