Quale meglio
roby 2
Iscritto: 10 Set 2008
MessaggioInviato: Dom 14 Ott, 2012 5:54 pm    Oggetto: Quale meglio Rispondi con citazione
Nella d300 meglio il raw 12 bit o 14? Grazie.
d.kalle
Iscritto: 29 Mgg 2008
MessaggioInviato: Dom 14 Ott, 2012 6:18 pm    Oggetto: Rispondi con citazione
Domanda un po' generica. Quanti aspetti che ti rispondano 12? Wink
Diverso: 14 invece di 12, ma ne vale veramente la pena?
ranton
Iscritto: 27 Set 2005
MessaggioInviato: Dom 14 Ott, 2012 6:38 pm    Oggetto: Rispondi con citazione
14-bit captures end up being only about twenty-five percent larger than 12-bit files, but the camera slows down considerably to get them. Maximum frame rate on the D300 drops from 6 frames per second with 12-bit raw to only 2.5 frames per second in 14-bit mode. For landscape work, it's probably acceptable, but for wildlife or sports shooters this would be painful. You'll probably need to consider what you are shooting and what the lighting conditions are like in order to decide but it would seem that 14-bit capture is not appropriate for everything.
http://www.earthboundlight.com/phototips/nikon-d300-d3-14-bit-versus-12-bit.html
