occhietto nuovo utente
Iscritto: 31 Gen 2011 Messaggi: 49 Località: milano
Inviato: Gio 22 Set, 2011 9:02 am Oggetto: D3000 tempi di scatto in "auto"sempre bassi |
ho da poco una nikon d3000 e ho notato in auto che apre e usa quasi sempre il flash anche se a mio parere non ne avrebbe bisogno ... ho provato a inquadrare il cielo in una giornata di sole e il tempo è salito a 1/125 sbaglio qualcosa? (ottica vr dx 18-55)
allego parte dei dati:
[Image]
Make = NIKON CORPORATION
Model = NIKON D3000
Orientation = top/left
X Resolution = 300
Y Resolution = 300
Resolution Unit = inch
Software = Ver.1.00
Date Time = 2011-09-22 08:35:52
YCbCr Positioning = co-sited
Exif IFD Pointer = Offset: 216
[Camera]
Exposure Time = 1/125"
F Number = F5.6
Exposure Program = Not defined
ISO Speed Ratings = 125
Exif Version = Version 2.21
Date Time Original = 2011-09-22 08:35:52
Date Time Digitized = 2011-09-22 08:35:52
Components Configuration = YCbcr
Compressed Bits Per Pixel = 4
Exposure Bias Value = ±0EV
Max Aperture Value = F4
Metering Mode = Pattern
Light Source = unknown
Flash = Flash did not fire, compulsory flash mode
Focal Length = 24mm
Maker Note = 27362 Byte
User Comment =
Subsec Time =
Subsec Time Original =
Subsec Time Digitized =
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 3872
Exif Image Height = 2592
Interoperability IFD Pointer = Offset: 28214
Sensing Method = One-chip color area sensor
File Source = DSC
Scene Type = A directly photographed image
CFA Pattern = [G,B],
[R,G]
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Digital Zoom Ratio = 1x
Focal Length In 35mm Film = 36mm
Scene Capture Type = Normal
Gain Control = None
Contrast = Normal
Saturation = Normal
Sharpness = Normal
Subject Distance Range = unknown
[Interoperability]
Interoperability Index = ExifR98
Interoperability Version = Version 1.0
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 300
Y Resolution = 300
JPEG Interchange Format = Offset: 28352
JPEG Interchange Format Length = Length: 9160
[Thumbnail]
Thumbnail = 160 x 120
[MakerNote (Nikon)]
Makernote Version = 0210
ISO Speed Used = 125
Quality = FINE
White Balance = AUTO
Focus Mode = AF-A
Flash Setting =
Auto Flash Mode =
White Balance Bias Value = 0, 0
White Balance Red, Blue Coefficients = 490/256, 335/256, 256/256, 256/256
000D = 00, 01, 06, 00
Exposure Diff = 00, 01, 0C, 00
ThumbOffset = 3758
Flash Compensation = 00, 01, 06, 00
ISO Speed Requested = 125
Photo corner coordinates = 0, 0, 3872, 2592
ecco la foto
 _________________ Nikon d3000 18-55 VR 55-200 VR sigma 70-200 apo ex 2.8 tamron 17-50 2.8 finepix s5600, lente macro per fuji autocostruita vecchia pentax me super, pentax 70/210, lumix tz2 14x |
Inviato: Gio 22 Set, 2011 9:46 am Oggetto: |
scusate ho sbagliato il titolo "tempi di scatto sempre alti" è il problema _________________ Nikon d3000 18-55 VR 55-200 VR sigma 70-200 apo ex 2.8 tamron 17-50 2.8 finepix s5600, lente macro per fuji autocostruita vecchia pentax me super, pentax 70/210, lumix tz2 14x |
d.kalle moderatore
Iscritto: 29 Mgg 2008 Messaggi: 20512 Località: Thiene
Inviato: Gio 22 Set, 2011 10:32 am Oggetto: |
1/125s a f5,6 e 125 ISO e' corretto, la macchina ha "ragionato" bene.
Se invece volevi dei tempi piu' rapidi potevi lavorare in A aprendo il diaframma a f4,5 (il tuo obiettivo a 24mm te lo permette), oppure alzare gli ISO (ad es. a 200 ISO).
Lavorando tutto in automatico e' abbastanza normale che il flash si attivi spesso, soprattutto utilizzandi gli obiettivi in kit, mai particolarmente luminosi.
Ultima cosa: immagino tu abbia ritoccato l'immagine in post, altrimenti mi preoccuperei....il cielo francamente fa schifo...  _________________
Inviato: Ven 23 Set, 2011 10:46 am Oggetto: |
non ho ritoccato nulla .. dici che c'è qualche problema?
ti invio altr foto non ritoccate sparate in auto
visto cho l'ho comprata usata se mi dai qualche consiglio se vuoi domani faccio altre foto (dimmi tu come) e te le mando
URL=http://imageshack.us/photo/my-images/840/immagine023ot.jpg/] [/URL]
Uploaded with [URL=http://imageshack
Uploaded with ImageShack.us _________________ Nikon d3000 18-55 VR 55-200 VR sigma 70-200 apo ex 2.8 tamron 17-50 2.8 finepix s5600, lente macro per fuji autocostruita vecchia pentax me super, pentax 70/210, lumix tz2 14x |
d.kalle moderatore
Inviato: Ven 23 Set, 2011 11:06 am Oggetto: |
Come fa a non essere ritoccata la prima? Queste 2 sono corrette come esposizione e anche colori. Guarda il cielo, e' azzurro, nella prima sembra posterizzato...
E il colore del muro? Rosa antico (penso sia corretto), mentre nella prima e' giallo...  _________________
Inviato: Ven 23 Set, 2011 11:20 am Oggetto: |
nessun ritocco proverò a farne altre questo we e poi le confronto , spero non sia un problema di macchina .. esistono delle prove da fare per vedere se tutto è ok? (sensore, esposimetro ecc ) _________________ Nikon d3000 18-55 VR 55-200 VR sigma 70-200 apo ex 2.8 tamron 17-50 2.8 finepix s5600, lente macro per fuji autocostruita vecchia pentax me super, pentax 70/210, lumix tz2 14x |
Max Stirner utente attivo
Inviato: Ven 23 Set, 2011 11:37 am Oggetto: |
Probabilmente nella prima in fase di compressione per il web deve esser stato fatto qualche pasticcio. _________________ "Quando ero giovane, mi esercitavo sempre mezz'ora al giorno. A volte riuscivo a credere anche a sei cose impossibili prima di colazione" |
