zelphir utente attivo
Iscritto: 20 Ago 2004 Messaggi: 572 Località: Palermo
Inviato: Mar 12 Ott, 2004 3:06 pm Oggetto: Info Tripod |
che ne dite di questo? lo vende il fotoamatore a 49€
il modello è Soligor LG-30
Tripods can guarantee perfect imaging quality and sharpness, even if the circumstances get difficult. A tripod therefore is an essential complement to your photo & video equipment. The LG-30 boasts of a high stability combined with an attractive modern design. Its ergonomically L-shaped grip guarantees fast and comfortable movements.
Specifications:
• 3 Sections with 30/27/24mm profiles
• 156.5cm length, extended
• 62cm length, folded
• Center column Ø 20mm
• Geared elevator
• Center column lock
• Center braces
• High stability due to closed-channel legs
• Inside one-touch leg locks
• 3-way photo & video panhead with fluid effect for pan & tilt movements for horizontal and vertical shots
• L-shaped grip
• Identical quick-set shoe for all "LG" and "RG" tripod models
• Bubble level
• Non-slip rubber tips
• Weight 1.5kg
• Color: reflex-free titanium |
