robbynaish utente
Iscritto: 23 Giu 2004 Messaggi: 116 Localitΰ: Frittole
Inviato: Gio 16 Set, 2004 7:57 am Oggetto: Nikon Coolpix 8800 con Nikon VR (lens element) |
The Coolpix 8800 was announced along with the 8400 and 4800 on the 16th September in the run-up to Photokina 2004. It's the first ten times optical zoom eight megapixel digital camera and it's also Nikon's first consumer digital camera with Vibration Reduction technology. The 8800 takes the 8700's design and engine and builds on it, on top of the new lens and Vibration Reduction there are a whole raft of new features and improvements which are also shared by the Coolpix 8400 (the two cameras are virtually identical apart from their lens and body design).
Major changes since the Coolpix 8700
New 10x optical zoom lens (35 - 350 mm equiv.; F2.6 - F4.9)
Vibration Reduction stabilization system
New 'Extra' JPEG compression (larger JPEG, lower compression)
Movie clips at VGA 30 fps up to 60 sec, QVGA limited only by storage
Maximum sensitivity now ISO 400
Exposure mode dial
Removal of play / record switch
Nine focus areas in manual area select, five areas in auto
Additional scene modes: Museum, Sports, Dusk / Dawn
AF Assist lamp on camera body instead of pop-up flash
Maximum shutter speed down to 1/3000 sec from 1/4000 sec
Continuous shooting down to 2.3 fps from 2.5 fps
Flash range up to 6.0 m at wide angle (compared to 4.1 m) - Auto ISO
Flash hot-shoe supports i-TTL and flash zoom
Playback zoom up to 10x
Included Infrared remote control
No Compact Flash card included
USB 2.0 Hi-Speed
Higher capacity Lithium-Ion battery (8.1 Wh vs. 5.0 Wh)
Price US: $ 999 MSRP
UK: £ ?
Body Material Magnesium alloy / Plastic
Sensor 8.3 megapixel (total) CCD
8.0 million effective pixels
2/3" Type (click here)
RGB Color Filter Array
Image sizes 3264 x 2448
3264 x 2176 (3:2)
2592 x 1944
2048 x 1536
1600 x 1200
1280 x 960
1024 x 768
640 x 480
Movie clips 640 x 480, 30 fps, max 60 sec
320 x 240, 15 fps, limited only by storage
With audio
Timelapse movie also available
File formats RAW (Nikon NEF)
TIFF (RGB)
JPEG (EXIF 2.2) - Extra, Fine, Normal, Basic
QuickTime (Movies)
Lens * 10x optical zoom "Nikkor ED " VR
35 - 350 mm equiv.
32 steps from wide to telephoto
F2.6 - F4.9
16 elements in 10 groups, 2 glass moulded ED elements
Motor zoom, single speed
Lens thread with optional adapter
Vibration Reduction * Lens shift (optical)
Digital zoom Yes, smooth up to 4.0x
Auto focus * Contrast detect TTL
Focus areas Auto select (five area)
Manual select (nine area)
Focus modes Continuous AF
Single AF
Manual focus
Focus range Normal (wide): 50 cm to Infinity (19.7 in to Infinity)
Macro (wide): 3 cm to Infinity (1.2 in to Infinity)
AF Assist lamp Yes, auto (LED)
Shooting mode Auto
Programmed AE with flexible program [P]
Shutter-Priority AE [S]
Aperture-Priority AE [A]
Manual [M]
Scene
Mode dial settings Image size / quality
ISO
White Balance
Scene modes Portrait
Party / Indoor
Night portrait
Beach / Snow
Landscape
Sunset
Night landscape
Museum
Fireworks show
Close up
Copy
Back light
Panorama assist
Sports
Dusk / Dawn
Metering 256-segment Matrix
Center-weighted
Spot
Spot AF area
Sensitivity Auto (50 - 200)
ISO 50
ISO 100
ISO 200
ISO 400
Shutter speed Auto & P: 2 to 1/3000 sec
S, A & M: 8 to 1/3000 sec
Bulb in M mode (up to 10 minutes)
At some apertures maximum shutter speed is 1/1500 sec
Shutter priority 8, 4, 2, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/125,1/250, 1/500, 1/1000, 1/1500, 1/3000
Aperture priority Wide: F2.8, F3.2, F3.6, F4.0, F4.5, F5.0, F5.6, F6.3, F7.1, F8.0
Tele: F5.2, F5.8, F6.6, F7.4
Manual exposure Any combination of shutter speed and aperture above
Bulb (up to 10 minutes)
AE Lock Yes, button
Exposure compen. -2 EV to +2 EV in 1/3EV steps
Exposure bracketing 3 or 5 images
+/- 0.3, 0.7, 1.0, 1.3, 1.7, 2.0 EV
Other bracketing Highlight BSS
Shadow BSS
Histogram BSS
White balance
White Balance Auto
Preset
Daylight
Incandescent
Fluorescent
Cloudy
Speedlight
Shade
WB fine tune Yes
Color space sRGB
Image parameters Sharpening: Auto, High, Normal, Low, Off
Tone: Auto, Normal, More contrast, Less contrast
Saturation: Auto, -2 to +2, B&W
Continuous Continuous H (2.3 fps, max 5 frames)
Continuous L (1.2 fps, max 11 frames)
Multi-shot 16 (16 frames, 1.6 fps, 1/16 size)
Ultra HS (VGA, 30 fps, max 100 frames)
5 shot buffer (1 fps)
Interval Timer Shooting
Flash * Built-in pop-up (electric)
Range: (Auto ISO) 0.5 - 6.0 m (Wide), 1.0 - 3.0 m (Tele)
Modes: Auto, Flash cancel, Red-eye reduction, Anytime flash, Slow Sync, Rear curtain sync
Pop-up: Automatic or Manual
External flash Standard ISO hot-shoe contact with safety lock
Hotshoe connects to external Nikon Speedlight SB-600/800/50DX/30/22s; built-in Speedlight can be canceled when using external Speedlight(s)
Supports i-TTL and flash zooming
Tripod mount Yes, metal
Self-timer 3 or 10 sec delay
Remote control Yes, included Infrared
Remote capture PC control via USB
Video out Yes, selectable NTSC / PAL
Storage Compact Flash Type I or Type II
IBM Microdrive supported
No CF card included
Viewfinder Electronic Viewfinder (0.44" LCD)
235,000 pixels
Dioptre adjustment (-3 to +1 dpt)
Frame coverage: 97% (record), 100% (play)
LCD 1.8" TFT LCD
Transmissive (semi-reflective)
Flip-out and twist
134,000 pixels
Brightness & Hue adjustment
Histogram display Live view
Playback
Connectivity USB 2.0 (Hi-Speed)
A/V out
DC-IN (8.4 V)
Power Nikon EN-EL7 Lithium-Ion rechargeable battery (7.4 V, 1100 mAh)
Optional MB-CP10 battery pack (6 x AA batteries)
Or EH-53 AC adapter
Weight (no batt) * 600 g (1.3 lb)
Weight (inc. batt) * 680 g (1.5 lb)
Dimensions * 116 x 85 x 121 mm (4.6 x 3.3 x 4.8 in)
Supplied accessories Lens Cap, Strap, USB Cable, Audio Video Cable, Rechargeable Li-ion Battery EN-EL7, Battery Charger MH-56, Remote Controller ML-L3, PictureProject CD-ROM _________________ ciao
Alessandro |
Giovanni utente
Iscritto: 10 Gen 2004 Messaggi: 73 Localitΰ: Milano
