AlexFoto utente attivo
Inviato: Ven 01 Nov, 2013 8:34 pm Oggetto: Cheetah Light CL-180 & CL-360 & CL-360II |
Cheetah Light CL-180 Combo
CL-180 Instruction Manual (pdf)
Cheetah Light CL-360
CL-360 Instruction Manual (pdf)
WITSTRO Powerful & Portable Flash //AD180 //AD360
CL-Tx,CL-Rx (pdf)
CL-Tx: Transmitter (1)
CL-Rx: Receiver
Cheetah Lithium 4500 mAh Battey Pack (pdf) : dovrebbe essere equivalente al Godox PB960.
In alcune recensioni viene detto che può essere usata pure la batteria Godox PB820.
Nel caso di alcuni modelli Canon è possibile pure abbinare un trasmettitore per usare l'High Speed Sync.
Cells-II CheetahSync Transmitter
News.
GODOX AD360II-C WITSTRO – TTL 2.4GHz Flash Announced!
Review.
Cheetah Light CL-180 (Godox Witstro AD180) flashgun review
Godox PB960 Lithium Power Pack – Review
The Cheetah Light CL-360 – a short review by Andrew
New Godox WITSTRO AD180, AD360 – Bare Bulb Flash – 180 & 360ws, Wireless Power Control.
CHEETAH or Godox AD180 / 360 – Radio Triggers and HSS
CheetahStand CL-180 and CL-360 Lights & Lithium Battery L-4500 Review by Robert Mitchell
Godox AD360 & PB960 Battery Pack Flash Review by Ben Evans
Godox – Witstro AD180 / AD360 Bare Bulb Flash – Review
A New Bare Bulb Flash Arrives
Godox – V850 & Witstro – Radio Trigger Alternatives
Quick Test – AD360 vs. AD600 vs. Einstein 640 by Mark Kitaoka
Video.
Cells II High Speed Sync Transmitter
Cheetah Light CL180 Review
Cheetah Light CL-180 on location
Cheetah Light CL-180 Mount on 50x50 softbox
Godox Witstro AD360 hands-on
Godox Witstro AD360 HSS with Yongnuo YN-622
GODOX WITSTRO AD360ii by Frank Suero
AD360II Review and Comparison by Charlie Brown Photography
Godox AD360II Unboxing + Menu Walkthrough (Flashpoint Streaklight 360 TTL / Cheetah Light 360x) by Robert Hall Photography
Godox 360II Cheetahlight 360X Sony & TT685 by Robs Photography
Nota:
1) L'unità trasmittente può essere usata pure in abbinamento con il flash:
Cheetah V850
Secondo un noto rivenditore fotografico italiano l'unità trasmittente e ricevente possono gestire i flash da studio:
Quantuum Up!, Move e Pulse
in modo completo.
I prodotti Lencarta, sia le edizioni da studio che quelle portatili, che dovrebbero essere dei Godox rinominati, confermerebbero questa possibilità dicendo che in remoto è possibile gestire:
potenza, accendere e spegnere la luce dei flash da studio, attivare o disattivare il suono, e consentire di testare il funzionamento del flash. _________________ AlexFoto
Ultima modifica effettuata da AlexFoto il Mar 04 Apr, 2017 7:01 am, modificato 46 volte in totale |
AleZan coordinatore
Inviato: Sab 02 Nov, 2013 12:50 pm Oggetto: |
Non mi sembra male, come portabilità e come scelta di accessori.
Certo non arriva alle caratteristiche di un Elichrome Ranger, ma costa anche un terzo....
Se si rivela un prodotto affidabile, può essere un'opzione interessante. _________________ Alessandro - www.alessandrozanini.it
Inviato: Lun 04 Nov, 2013 9:55 am Oggetto: |
Guardando in Rete mi pare che il Genesis Reporter 180 sia il Cheetah Light CL-180 a cui è stato cambiato soltanto il nome.
In questo caso, su ebay, si trova già presso un rivenditore fotografico italiano.
Riflettendo sulla potenziale problematica indicata nell'articolo relativamente alla lampada esterna penso che già l'uso della parabola dovrebbe essere sufficiente a garantire che in caso di caduta (ipotizzabile soprattutto in esterni) non dovrebbero esserci problemi.
Stessa cosa nel caso fosse usato senza parabola ma con abbinato diffusori (ombrelli o softbox). _________________ AlexFoto
AleZan coordinatore
Inviato: Lun 04 Nov, 2013 2:02 pm Oggetto: |
Hanno la stessa potenza?
Mi era sembrato di vedere uno con NG 60 e l'altro con NG 80 a 100 ISO
Ma forse mi sbaglio... _________________ Alessandro - www.alessandrozanini.it
Inviato: Lun 04 Nov, 2013 8:51 pm Oggetto: |
L'edizione da 180 dovrebbe avere un NG di 60 mentre il 360 di 85.
Se però andiamo a guardare il manuale del 180, dividendo, spunterebbe 80.
Sostanzialmente basandomi sulle immagini mi pare che lo stesso prodotto sia proposto usando 3 nomi diversi. _________________ AlexFoto
Ultima modifica effettuata da AlexFoto il Mar 29 Apr, 2014 7:57 am, modificato 1 volta in totale |
AleZan coordinatore
Inviato: Lun 04 Nov, 2013 9:08 pm Oggetto: |
Anche a me sembra lo stesso.
Se avesse un NG 60 avrebbe di fatto una potenza paragonabile agli Speedlite top gamma di Canon e Nikon.
Allira non so se la batteria esterna e gli accessori giustificherebbero la scelta. _________________ Alessandro - www.alessandrozanini.it
Inviato: Lun 04 Nov, 2013 9:13 pm Oggetto: |
CHEETAH Light CL-180 – Bare Bulb HSS Flash – Review
Qui è presente una conferma che almeno due dei nomi indicati indicano la stessa cosa.
Cioè pare essere frutto di una collaborazione tra due produttori diversi e l'utente di un forum internazionale.
Godox Witstro AD360 – the flash you have been waiting for
Cenni su compatibilità con radio trigger di terze parti.
Supponendo che come indicato nelle recensioni risulti essere un prodotto valido penso che le potenziali problematiche rimanenti siano essenzialmente due:
- nessun supporto degli automatismi (sebbene la parziale eccezione data da alcuni modelli Canon)
- alimentazioni con batterie al litio proprietarie (inevitabile data la potenza)
Quindi occorrerebbe preventivare almeno una batteria di riserva.
E, come al solito, le batterie al litio hanno la caratteristica di perdere capacità, con il passare del tempo, indipendentemente dal numero massimo di ricariche teoricamente disponibili, quindi se un domani il produttore smettesse di produrle, e nessun altro si facesse avanti (i contatti che si vedono in foto mi danno qualche pensiero), nonché l'intrinseco problema riguardante la sicurezza delle batterie al litio (almeno in assenza di innovazioni).
Anche se a differenza di un cellulare o simili si presuppone che un flash esterno non si trovi a pochi cm dall'utilizzatore.
| AleZan ha scritto: | | non so se la batteria esterna e gli accessori giustificherebbero la scelta. |
Da tenere però pure presente che il flash con il battery pack, senza i trigger, nell'edizione 180, si trova a circa 300 euro, cioè quanto un Nikon SB710 (Nital), mentre l'equivalente Canon, nonostante costi di meno, non supporta ad es. la gestione master.
Quindi, in teoria, almeno per gli utenti Canon e Nikon, una configurazione mista:
Nikon SB710 o Canon 430
potrebbe risultare un compromesso accettabile.
Anche se forse ci sarebbe da considerare pure la gestione di una temperatura colore diversa dovuta all'uso di unità diverse.
Però considerando che la temperatura colore di un flash varia in ogni caso, in funzione della potenza di scatto e che il range di variazione risulta maggiore rispetto alle migliori unità da studio, magari questo potrebbe non risultare un problema importante.
In questo modo sarebbe possibile combinare un certo automatismo con l'ulteriore possibilità di non rimanere fermi nel caso la batteria al litio del 180 si fosse scaricata in un momento inopportuno.
Senza dovere per forza includere un ulteriore, costosa, batteria litio di riserva.
Chiaro, rimanendo con un singolo flash.
Poi ovviamente chi ha modo di guadagnare bene facendo fotografia può benissimo aggiungerla in modo da avere maggiore garanzia d'uso di due fonti di illuminazione.
Questo supponendo che queste unità risultino davvero valide.
Informal Manual Strobe Output Comparison
Nota:
La relativa limitata distanza d'uso di queste unità dipende dalle frequenze radio scelte.
Bare Bulb Genesis (calumet) GF400/GF200, GODOX witstro AD180/AD360, CHEETAH CL180/CL360
Elenco dei diversi marchi in cui viene commercializzato questo prodotto. _________________ AlexFoto
mnoga utente
Iscritto: 08 Gen 2009 Messaggi: 209 Località: vicenza
Inviato: Mer 05 Feb, 2014 5:24 pm Oggetto: |
| buongiorno, io sarei interessato ai flash in oggetto, ma rispetto agli introvabili quantuum dual power 300 o 600, come li vedete? |
Inviato: Ven 14 Feb, 2014 8:42 pm Oggetto: |
La solidità costruttiva dovrebbe risultare superiore ai Quantuum.
Sono sicuramente più portabili e con maggiore autonomia.
Ma non essendo flash da studio, non dispongono di una lampada pilota. _________________ AlexFoto
mnoga utente
Inviato: Ven 14 Feb, 2014 9:06 pm Oggetto: |
| e come potenza? |
Inviato: Ven 14 Feb, 2014 9:12 pm Oggetto: |
Per la potenza dovresti guardare l'NG (numero guida) o GN (guide number) dei Quantuum per tentare un paragone con questi flash.
Dato che nel Cheetah la lampada è di tipo esterno, il confronto delle potenze, dovrebbe comportare una buona approssimazione. _________________ AlexFoto
mnoga utente
Inviato: Sab 15 Feb, 2014 12:18 pm Oggetto: |
ti ringrazio intanto
dove li trovate in vendita? ho provato a cercare un po' ma non ho trovato granché .. |
Inviato: Mer 23 Apr, 2014 4:07 pm Oggetto: |
Si trovano in Rete usando uno dei diversi nomi indicati in precedenza, tanto si tratta della stessa unità, ridenominata.
I Lencarta Atom 180 & Atom 360 dovrebbero essere gli equivalenti Godox AD180 & AD360. _________________ AlexFoto
