Come tarare un obiettivo ad un corpo Canon
Mais78
Iscritto: 22 Apr 2010
MessaggioInviato: Gio 14 Mar, 2013 10:13 pm    Oggetto: Come tarare un obiettivo ad un corpo Canon Rispondi con citazione
Ho trovato in rete un metodo infallibile per calibrare obiettivi a corpi Canon...
Ve lo copio sotto sperando di farvi cosa gradita, tanto semplice quanto geniale, altro che Focal, basta EOS utility, molto piu' semplice! Ci metti due secondi a scattare in live view usando focus sul sensore (massima precisione) e l AF della macchina. Quando il secondo, dopo gli aggiustamenti, e' uguale al primo il gioco e' fatto.
Focal spesso da risultati molto diversi, con questa procedura invece vedo con i miei occhi qual e' il microadjustment ottimale.
Arash Hazeghi's method (my notes in red)
"Pin the target to the wall at a distance ~25-50 times the focal length, for a zoom lens choose the focal length that you use most often.
First use the spirit level on the ball head to level the camera in XY plane. It is essential that sensor plane is parallel to target. To do this you can use a small mirror, tape it to the target look through the camera’s finder until you can see the centre of your lens in the mirror and lock down your tripod. Optical axis is now perpendicular to target and you are done with the mirror.
I skip this step, just setting up quickly by eye.
You must have Canon EOS utility application installed on your machine, this is included with every Canon camera, if you have an older version make sure to go to Canon’s website and download the latest update.
You are ready for micro adjust now. Follow these steps:
First set the camera to Av mode and select the centre AF point. Dial in any necessary exposure compensation to get the exposure correct on your target.
1) Connect the camera to your computer via the USB cable that came with the camera and cancel any image download pop-up/application
2) Run EOS utility.
3) Click on Camera setting/remote shooting icon
The camera should now magically switch into liveview
4) Click on Remote Live View Shooting. This will open a new window with live sensor video feed 5) Make sure AF is in phase detect mode (Quick mode AF) that uses the camera’s main AF sensor. This is found within the Liveview menu
6) Choose the centre AF point and make sure the white rectangle is centred on the AF point
7) Click on the magnifying icon for a full size view .
8) Click AFON button the camera will now perform AF. (ndr io invece uso il pulsante disponibile nell'ultima versione di EOS utility)
If you have assigned any function to the camera AF ON button within the custom functions then you will need to reset it temporarily back to the default or the camera might not focus!
9) Click on 200% magnification, you are now viewing the sensor output at 2:1). Note it is essential that the tripod be placed on a solid surface plus nobody should walk in the proximity of the setup or you will see vibrations on the screen!
10) Now click on the ( > ) or( < ) buttons to shift focus back or front one click at a time until image appears sharpest on the screen, notice the contrast edges, you want them as crisp as possible. Write down how many clicks you have moved relative to the centre, infinity symbol indicates far direction
11) Repeat this a few times until results are consistent.
It is best to defocus the lens and get the camera to refocus within EOS Utility a few times to check for consistency.
12) Each click on the ( > ) or ( < ) corresponds to one unit in the AF micro adjust scale in the camera.
e.g. if you clicked the > icon 3 times in the + direction then dial in +3 into the camera Lens microadjustments
13) Disengage LV by clicking "close" in the Zoom View and Remote Live View Windows.
14) Go to MA menu option in your camera and dial in the exact value noting the back or front direction.
15) Go back to step 3 and perform AF again, if the image is already as sharp as possible when you click 200% you are done, if not iterate until you can repeatedly get the sharpest image.
Your camera and lens static AF should be adjusted with great accuracy now. "
Mais78
MessaggioInviato: Gio 14 Mar, 2013 10:20 pm    Oggetto: Rispondi con citazione
Trovato anche il sito originale
http://arihazeghiphotography.com/MA-web/
M@n
Iscritto: 02 Ago 2007
MessaggioInviato: Ven 15 Mar, 2013 11:35 am    Oggetto: Rispondi con citazione
Che dire se non un grazie grande cosi'?
Canon 5d3 con un po' di lenti Canon e questi vintage Pentacon 135/2.8 Samyang 14/2.8 Zenitar 16/2.8 MIR-1B 37/2.8 Zuiko 50/1.4 Pentacon 29/2.8
Suzuki SV My Flickr
NEMMENO IL FATO LI VINSE: Bacigalupo Ballarin Maroso Grezar Rigamonti Castigliano Menti Loik Gabetto Mazzola Ossola
Pio Baistrocchi
Iscritto: 30 Ago 2007
MessaggioInviato: Ven 15 Mar, 2013 12:42 pm    Oggetto: Rispondi con citazione
Assolutamente da provare,grazie!
Mais78
MessaggioInviato: Ven 15 Mar, 2013 1:24 pm    Oggetto: Rispondi con citazione
Piu' facile da fare che da spiegare, ci vogliono poche decine di secondi a lente e a differenza di Focal non serve neanche scattare.
aral70
Iscritto: 21 Feb 2010
MessaggioInviato: Sab 16 Mar, 2013 8:58 am    Oggetto: Rispondi con citazione
c'e' qualche anima buona che me lo puo' tradurre!
grazie!
Mais78
MessaggioInviato: Sab 16 Mar, 2013 2:25 pm    Oggetto: Rispondi con citazione
In sostanza:
metti la macchina su treppiede o supporto stabile ed un immagine target (se ne trovano tante su internet) ad una distanza tra 20 e 50x la distanza focale.
Colleghi macchina a computer tramite porta usb. Apri EOS utility e scegli l opzione per scattare in live view. Dal menu a tendina scegli la modalita' di messa a fuoco quick mode (che usa il sensore AF), clicca sull ingrandimento a 200% e metti a fuoco premendo su ON (aiutati con le immagini sul sito linkato). A questo punto clicca su < o > per raggiungere la messa a fuoco ottimale. Conta quante volte devi cliccare su < o >, ogni click corrisponde ad uno step di microadjustment da imputare nella macchina per avere fuoco ottimale. Ripeti l'esperimento 5 o 6 volte per assicurarsi che il valore ottimale sia grosso modo sempre lo stesso.
Aggiungo io: per verificare che il fuoco raggiunto con < e > sia corretto, dal menu messa a fuoco passa da quick mode a flexi (quello che usa il sensore di immagine per mettere a fuoco) e riclicca su ON, i due devono essere identici o quasi, la messa a fuoco piu' precisa e' sempre quella in live view/flexi quindi e' il tuo benchmark.
aral70
MessaggioInviato: Dom 17 Mar, 2013 12:29 am    Oggetto: Rispondi con citazione
grazie infinite per la spiegazione in italiano!
Fringuello
Iscritto: 09 Ago 2007
MessaggioInviato: Mer 28 Ago, 2013 9:56 pm    Oggetto: Rispondi con citazione
ottimo
Un Mondo perfetto è un mondo senza sogni -- Il mio nuovo sito in costruzione -- Il mio spazio su Flickr
