setu utente attivo
Iscritto: 26 Dic 2005 Messaggi: 1293 Località: Rescaldina
Inviato: Sab 17 Lug, 2010 1:46 pm Oggetto: Le specifiche della nuova LX5 |
Prima che eventualmente le tolgano. Verrá presentata il 21.
Anche in color bianco.
Accetterà mirino esterno elettronico e ottico.
Lo zoom passa a 24-90mm
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-LX5W
Camera Effective Pixels
Effective Pixels
Slightly less than the total number of pixels normally stated for an image sensor (CCD, CMOS, etc.), this term represents the actual number of pixels used to record an image.
10.1 Megapixels
Sensor Size / Total Pixels / Filter 1/1.63-inch / 11.3 Total Megapixels / Primary Color Filter
Aperture F2.0 - 3.3 / Multistage Iris Diaphragm (F2.0 - 8 (W) / F3.3 - 8 (T))
(F2.0 - 11 (W) / F3.3 - 18 (T) in movie recording)
Optical Zoom
Optical Zoom
As the focal length of a zoom lens is changed, the subject is magnified. When an image is magnified via the lens, the resulting image looks natural.
3.8x
Digital Zoom
Digital Zoom
(for Camcorders)
Through the use of digital technology, the zoom ratio on select Panasonic camcorders can be increased to an amazing 700:1 or greater, depending on the model. After the highest optical zoom setting is reached, the digital zoom automatically takes over, magnifying the image by blowing up the pixels to give you an incredibly close shot.
(for Digital Cameras)
A feature found in many digital cameras that takes a portion of the image's data and displays it at full size, producing an enlargement (magnification) of the original image, similar to the effect of using a telephoto lens. This process, however, is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
4x
( Max. 15.1 x combined with Optical Zoom without Extra Optical Zoom)
(Max. 26.8 x combined with Extra Optical Zoom)
Focal Length
Focal Length
The distance from the middle point of the lens to the focus point. Assuming that the camera's position is fixed, the larger this value becomes, the larger the subject appears (telephoto). Conversely, the smaller this value becomes, the smaller the subject becomes (wide angle).
f=5.1-19.2mm (24-90mm in 35mm equiv.)
(25-95mm in 35mm equiv. in movie recording)
Lens LEICA DC VARIO-SUMMICRON
10 elements in 9 groups
(3 Aspherical Lenses / 5 Aspherical surfaces)
Optical Image Stabilizer Power O.I.S. (Off / Auto / Mode1 / Mode2)
Photo & Movie
Conversion Lens Compatibility Yes
Focusing Area Normal: Wide/Tele 50 cm - infinity
Macro / Intelligent AUTO / Wide 1 cm - infinity / Tele 30cm - infinity
Focus Range Display Yes
AF Metering Face / AF Tracking / Multi (23pt) / 1pt (flexible / scalable)
Focus Normal / Macro Quick AF On/Off (On in Intelligent Auto), Continuous AF On/Off
AF/MF Switchable, Manual Focus(Jog Dial), One Shot AF, AF Area Select, AF Tracking
AF Assist Lamp
AF Assist Lamp
Provides extra lighting as a focusing aid for slightly dark situations where AF focusing would ordinarily be difficult.
Yes
ISO Sensitivity
ISO Sensitivity
A value used to indicate a film's sensitivity to light. ISO also stands for the International Standards Organization. Since no similarly defined standard exists for digital cameras, the term "ISO 100 equivalent" is used. A larger ISO value indicates that the camera can take a better picture in dimly lit locations (such as indoors).
Auto / i.ISO / 80 / 100 / 200 / 400 / 800 / 1600 / 3200 / 6400* / 12800* (* by pixel mixed readout)
High Sensitivity (ISO 1600-12800)
White Balance
White Balance
Definition:
Provides color temperature correction when taking photographs at different times on a sunny day, or in different types of artificial lighting.
How does it work?
White Balance adjusts automatically. However, depending on the scene or light condition, the Automatic White Balance may not be able to bring out natural colors. In such cases, the White Balance can be adjusted manually. While differences exist between Auto White Balance and Manual White Balance types, this feature is found on every digital camera.
Auto/Daylight/Cloudy/Shade/Flash/Halogen/Color Temperature/ White Set 1 / 2
White Balance Note (Selectable at Normal Portrait,Soft Skin,Creative Portrait,Normal Sports,Creative Sports,Objects Close-up,Creative Close-up,Baby,Pet,High Sensitivity,Hi-Speed Burst,Panorama Assist,Photo Frame mode)
White Balance Adjustment 2-axis adjustable, ±9steps each, Blue/Amber and Magenta/Green bias
Exposure
Exposure
The amount of light that strikes the image sensor or film. If the exposure period is too long, the image is "overexposed" and if it is too short, the image is "underexposed."
Program AE, Aperture Priority AE, Shutter Priority AE, Manual, Program Shift(Program AE Mode)
Exposure Compensation
Depending on the subject's degree of reflectance or lighting condition, AE photography can easily produce exposures that are either over or under the optimum. To compensate for this type of error, plus or minus compensation can be added to correct the exposure, which is called exposure compensation.
1/3 EV Step, ± 3 EV
Backlight Compensation Yes (only in Intelligent AUTO mode)
Auto Bracketing
Auto Bracketing
Automatically takes multiple pictures with a single press of the shutter, each using a different exposure. (Usually average, over and under exposed) This reduces the chance of an incorrect exposure. After shooting, you can look at the results and keep the best shot.
(AE
AE
Abbreviation for Automatic Exposure. The camera's exposure sensor measures the brightness of the subject and automatically calculates an exposure. Generally, there are three types of AE: Program AE, Aperture Priority AE and Shutter Priority AE.
) +/- 1/3 EV ~3EV step, 3 frames
Light Metering Intelligent Multiple
Measures the light at points across the entire image to achieve a balanced exposure setting.
/ Center-weighted
Center-weighted
This metering system places greatest importance on the central part of the image and measures the average overall brightness of the scene. Very commonly used, this system is found in most digital cameras.
/ Spot
Spot
Uses a small point in the center of the screen to meter exposure. Useful in many situations, such as when the subject and background have extreme light and shadow differences, such as with stage or back lighting.
Face Detection Photo & Movie
Still Image Scene Mode Portrait, Soft Skin, Self-Portrait, Scenery, Panorama Assist, Sports, Night Portrait, Night Scenery, High Sensitivity, Food, Party, Candle Light, Baby1/2, Pet, Sunset, Hi-Speed Burst, Flash Burst, Starry Sky, Fireworks, Beach, Snow, Aerial photo
Movie Scene Mode Portrait, Soft Skin, Self-Portrait, Scenery, Low Light, Food, Party, Candle Light, Sunset, Beach, Snow, Aerial, Pinhole, High Sensitivity
Movie Scene Mode Note (Activated by selecting Still Picture Scene Mode then pressing movie button. Still Picture Scene Modes without corresponding Movie Scene Mode is recorded in Normal Mode)
Shutter Interval approx. 0.5 sec
Self Timer
Self Timer
An automatic feature that provides a delay after the photographer presses the shutter until the shutter actually opens, to allow the photographer to take a self-portrait or pose in a family group picture, and to reduce hand-shake.
2sec / 10sec
Auto Review 1sec, 2sec, Hold, OFF
Picture Adjustment Contrast +2steps
Sharpness +2steps
Saturation +2steps
Noise Reduction
Image Quality RAW, RAW+Fine, RAW+Standard, Fine, Standard
4:3 Aspect Ratio (Still Image) 3648x2736(10M) / 3072x2304(7M)/ 2560x1920(5M) / 2048x1536(3M) / 1600x1200(2M) / 640X480(0.3M)
3:2 Aspect Ratio (Still Image) 3776x2520 (9.5M) / 3168x2112 (6.5M) / 2656x1768 (4.5M) / 2112x1408 (3M) / 2048x1360 (2.5M) / 640x424 (0.3M)
16:9 Aspect Ratio (Still Image) 3968x2232 (9M) / 3328x1872 (6M) / 2784x1568 (4.5M) / 2208x1248 (2.5M) / 1920x1080 (2M) / 640x360 (0.2M)
1:1 Aspect Ratio (Still Image) 2736x2736(7.5M) / 2304x2304 (5.5M) / 1920x1920 (3.5M) / 1536x1536 (2.5M) / 480 x 480 (0.2M)
Motion Picture Recording 4:3 VGA: 640 x 480 pixels, 30fps (Motion JPEG)
QVGA: 320 x 240 pixels, 30 fps (Motion JPEG)
Motion Picture Recording 16:9 WVGA: 848 x 480 pixels, 30 fps (Motion JPEG)
Motion Picture Recording HD Movie 1280x720 pixels,60p(CCD output is 30p)
(AVCHD Lite, SH: 17Mbps / H:13Mbps / L:9Mbps)
/ 30fps (Motion JPEG)
Aspect Ratio 4:3, 3:2, 16:9, 1:1
Intelligent Exposure Photo & Movie
Real-time Histograms
This graph, which can be displayed in the LCD monitor as you line up the shot, shows the status of the exposure and contrast in real-time.
Yes
Composition Guide Lines
Displayed in the viewfinder and LCD, these thin horizontal and vertical lines make it easy for you to compose your shots or to hold the cameral level.
Yes (3 patterns)
Scene Mode Help Screen Yes
External Flash Yes
Viewfinder
Viewfinder
Allows the photographer to confirm the image's angle of view, which in turn allows adjustment (trimming, etc.) of the image's layout and composition.
(optional OVF/EVF)
LCD Monitor 3.0" TFT Screen LCD Display (460K dots), AR Coating
Field of View : approx. 100% Wide Viewing Angle
AUTO Power LCD mode, Power LCD mode
High CRI (Color Rendering Index) LED backlight
Film Mode Standard / Dynamic / Nature /Smooth / Vibrant / Nostalgic / Standard B&W / Dynamic B&W / Smooth B&W / My Film 1, 2 / Multi Film
*Works for movie recording
Playback Mode Normal Playback, Slideshow, Category Playback, Mode Playback, Favorites Playback
OSD Language English, Spanish
Recording Media Built-in Memory, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Interface AV Output (NTSC), mini HDMI, USB2.0 High speed
Viera Link Yes
Power ID-Security Li-ion Battery Pack (3.6V, Minimum: 1250mAh) (Included)
AC Adaptor (Input: 110-240V AC) (Optional)
Battery Life
Battery Life
Shooting conditions: 73.4°F with 50% humidity;LCD On; Using an SD Memory Card; Starting to shoot 30 seconds after turning on the power; Shooting once every 30 seconds with the flash in full operation for every other shot; Changing the zoom setting from telephoto to wide, or wide to telephoto, for each shot; Temporarily turning the power off after each 10 shots (long enough to lower the battery temperature. For DMC-LC1: Shooting once every 30 seconds, flash in operation for every shot, 77°F(25°C) ambient temperature.
400 pictures (CIPA Standard)
Built-in-Flash Auto, Auto/Red-eye Reduction, Forced On, Slow Sync./Red-eye Reduction, Forced Off,Flash Synchro; 1st / 2nd
0.8 - 7.2m (Wide/ISO Auto), 0.3 - 4.4m (Tele/ISO Auto)
Included Software PHOTOfunSTUDIO 5.0 HD Edition, SILKYPIX Developer Studio 3.1 SE, QuickTime, Adobe Reader
Standard Accessories Battery Charger, Battery Pack, AV Cable,USB Cable, Shoulder Strap, CD-ROM,Lens Ring Front, Hot Shoe Cover, Lens cap, Lens cap string
Multi-Aspect Yes
2-Speed Zoom No
Step Zoom Yes
Max Auto ISO Setting Yes
Quick Menu Yes
Continuous Shooting Mode Full-Resolution Image, 2.5 frames/sec Max. 5 images (Standard mode), Max. 3 img (Fine Mode)High-speed Burst Mode: approx. 6 frames/sec (img priority) approx. 10 frames/sec (speed priority) recorded in 3M for 4:3,2.5M for 3:2,2M for 16:9,2.5M for1:1)
Focus Icon Select Yes (in Face Recognition only)
Optical Zoom in Motion Picture Yes
Macro Zoom No
Orientation Detector Yes
Playback Motion Picture Yes ( AVC HD Lite / Motion JPEG)
Slideshow Mode All / Still Images Only / Motion Picture Only / Category / Favorites BGM Effect (Natural / Slow / Swing / Urban / OFF)
Show Histogram Yes
Show Highlights Yes
Delete Image Single / Multi / All / All except Favorites
Cut Animation Yes
PictBridge Support Single / Multi / All / Favorites / DPOF
AVCHD / AVCHD Lite REC NTSC
One-Touch Movie Button Yes
Movie REC Guide Yes
Wind-Cut in Motion Picture Yes
Flash Burst Continuous Shooting Mode Max. 5 images (Standard mode)
Continuous recordable time (Motion images) AVCHD or AVCHD Lite with picture quality set to [FSH or SH] approx.140 min
MOTION JPEG with picture quality set to [HD] approx.140 min
Actual recordable time (Motion images) AVCHD or AVCHD Lite with picture quality set to [FSH or SH] approx.70 min
MOTION JPEG with picture quality set to [HD] approx.70 min
My Color Mode Expressive /Retro / Pure / Elegant / Monochrome / High Dynamic / Dynamic Art / Dynamic B&W / Silhouette / Pinhole / Film Grain / Custom / Happy (only in iA mode)
*For movie recording
Intelligent ISO Control Photo
Face Recognition Photo
Intelligent Scene Selector Photo (Portrait, Scenery, Night Portrait, Night Scenery, Sunset, Macro) & Movie (Portrait, Scenery, Low Light, Macro)
File Format Still Image: JPEG(DCF/Exif2.3)
Image with Audio: JPEG (DCF / Exif2.3) + QuickTime
Motion picture: AVCHD Lite, QuickTime Motion JPEG
Mode Dial / Mode Button Intelligent AUTO, P(Program) mode, A(Aperture Priority) mode, S(Shutter Priority) mode, M(Manual) mode, Creative Movie mode, My Color mode, Scene mode, Custom 1,2
Copy / Title Edit / Text Stamp Yes / Yes / Yes
Dimensions (W x H x D) 4.32 x 2.58 x 1.69 in / excl. protrusions: 1.00 in
Weight(lbs) Approx. .61lb with Battery and SD Memory Card
Approx. .51lb without Battery and SD Memory Card
Extra Optical Zoom (EZ) 4.5x (4:3 / 7M), 5.4x (4:3 / 5M), 6.7x (4:3 / under 3M)
Shutter Speed Still: 60 - 1/4000 sec
Movie Mode : 1/30 - 1/20,000 sec (1/8 - 1/20,000 sec on MF operation on Creative Movie mode)
Starry Sky Mode : 15, 30, 60sec.
Digital Red Eye Correction (Red-Eye Removal) Photo
Mode Switch [Playback] button
Easy Zoom / Zoom Resume No / Yes
Thumbnails / Zoomed Playback 12,30-thumbnails / Max 16x
Calendar Display / Dual-Image Playback Yes / No
Set Favorites / Rotate Image Yes / No
DPOF Print Setting / Set Protection Yes / Yes
Resize / Trim / Aspect Conv. / Leveling Yes / Yes / No / Yes
Travel Date / World Time Yes / Yes
Built-in-Memory Approx. 40MB
Microphone / Speaker Mono / Yes
Touch Panel No
Intelligent Zoom 5.0x
AF Tracking Photo
Intelligent Resolution Technology Photo & Movie
Video Divide Yes
Face Recognition Edit Yes
HDMI output Video: Auto / 1080i / 720p / 480p
Audio: Mono _________________ Fiji X E1 - 18-55m |
biancoblu utente attivo
Iscritto: 16 Ott 2006 Messaggi: 849 Località: genova
Inviato: Sab 17 Lug, 2010 2:39 pm Oggetto: |
questo si che e' un'aggiornamento interessante...
mi sembrava strano che mettessero un sensore 4/3...pero magari avranno anche migliorato il software..una bella tentazione..vedremo un po'.. _________________ FUJI f31-OLYMPUS c770-CANON a80-OLYMPUS mjuII-PRAKTIKA BX20 |
setu utente attivo
Inviato: Sab 17 Lug, 2010 2:55 pm Oggetto: |
Quella simile a questa con sensore 4/3 e ottica non intercambiabile (con sensore 4/3 e ottica intercambiabile c'è già la GF1) dovrebbe uscire a settembre e dovrebbe essere moooooolto interessante. _________________ Fiji X E1 - 18-55m |
Cerby utente
Iscritto: 01 Ago 2008 Messaggi: 461 Località: Umbertide - PG
Inviato: Sab 17 Lug, 2010 3:44 pm Oggetto: |
BEL-LIS-SI-MA.
Se così fosse allora: buon lavoro Pana.
Hanno risolto l'unico piccolo neo dell LX3: l'escursione zoom. Ora con un 24-90 ci si fa davvero tutto. _________________ Andrea |
setu utente attivo
Inviato: Sab 17 Lug, 2010 4:01 pm Oggetto: |
Trovo utile anche la possibilità del visore esterno. Sulla LX1 mi manca. _________________ Fiji X E1 - 18-55m |
MacLo utente
Iscritto: 11 Nov 2006 Messaggi: 409 Località: RG
Inviato: Dom 18 Lug, 2010 12:41 am Oggetto: |
bè.. tutto sammato sto giro salto.. mi tengo la LX3.. magari verso fine anno penserò alla GF1... (vediamo che presenteranno). _________________ NIKON D80 | LUMIX LX3 l NIKKOR 18-55 l NIKKOR 24 | SIGMA 70-300 | SIGMA DP1 + HA11 + NIKON WC-E68 | VENDO: Oly E-520 | 14-42mm | 40-150mm | 50mm | Pentax K-X 18-55 55-200 |
My Flickr |
silvan utente attivo
Iscritto: 22 Giu 2004 Messaggi: 2873
Inviato: Dom 18 Lug, 2010 8:08 am Oggetto: |
da ex possessore della LX3 in questo modello, sicuramente migliorato ed appettibile, ci manca solo una cosa:
il video Full HD (1080)
setu utente attivo
Inviato: Dom 18 Lug, 2010 8:52 am Oggetto: |
Crackeranno anche questa, come la GF1 e la GH1  _________________ Fiji X E1 - 18-55m |
fabr1zio utente
Iscritto: 16 Apr 2008 Messaggi: 108 Località: Pisa (da Bari)
Inviato: Dom 18 Lug, 2010 10:00 am Oggetto: |
qual è il tempo di syncro flash? _________________ DOH |
MacLo utente
Inviato: Dom 18 Lug, 2010 10:55 pm Oggetto: |
vediamo se stavolta si potrà zoomare e focheggiare facendo i video!!  _________________ NIKON D80 | LUMIX LX3 l NIKKOR 18-55 l NIKKOR 24 | SIGMA 70-300 | SIGMA DP1 + HA11 + NIKON WC-E68 | VENDO: Oly E-520 | 14-42mm | 40-150mm | 50mm | Pentax K-X 18-55 55-200 |
My Flickr |
capellimario utente attivo
Iscritto: 18 Feb 2010 Messaggi: 950
Inviato: Lun 19 Lug, 2010 12:16 pm Oggetto: |
| ma l'apertura? |
Inviato: Lun 19 Lug, 2010 12:18 pm Oggetto: |
| ok, trovata. resta però da vedere a quanto mm sale sopra i 2,8.se è a 2 a 24 e a 40 è già a 3,3... |
andy_g utente attivo
Inviato: Mar 20 Lug, 2010 1:38 pm Oggetto: |
| fabr1zio ha scritto: | | qual è il tempo di syncro flash? |
Non essendo una micro4/3 non dovrebbe avere otturatore a tendina, così come non lo avevano le precedenti LX, e quindi neanche tempo di syncro-flash. Semplicemente si sincoronizza con qualsiasi tempo. _________________ Andrea - Le mie foto di viaggio: qui e qui
_Thor_ utente
Iscritto: 12 Mar 2007 Messaggi: 486
Inviato: Mar 20 Lug, 2010 6:45 pm Oggetto: |
> 10.1 Megapixels
Ecco la scelta più intelligente.
Canon ha rotto con la corsa al MP, meglio sarebbe puntare su macchine di qualità, che non abbiano gravi difetti e non caschino a pezzi... _________________ Freedom! Forever! |
MacLo utente
Inviato: Mar 20 Lug, 2010 11:43 pm Oggetto: |
tanti megapixel poi voglion dire che fai la foto a caso e poi croppi.. ma per favore!!
La 7D è a 18Mpx.. non oso immaginare la prox...
Comunque se mi volete regalare la 7D.. non mi offendo!!  _________________ NIKON D80 | LUMIX LX3 l NIKKOR 18-55 l NIKKOR 24 | SIGMA 70-300 | SIGMA DP1 + HA11 + NIKON WC-E68 | VENDO: Oly E-520 | 14-42mm | 40-150mm | 50mm | Pentax K-X 18-55 55-200 |
My Flickr |
Tomash utente attivo
Inviato: Mer 21 Lug, 2010 8:33 am Oggetto: |
Otturatore centrale, sincoronizza su tutti i tempi.
Testato personalmente sulla LX3 e suppongo che questa nuova LX5 abbia lo stesso otturatore.
Attendo il prezzo e mi sa che un pensiero ce lo faccio. |
d.kalle moderatore
Iscritto: 29 Mgg 2008 Messaggi: 20572 Località: Thiene
Inviato: Mer 21 Lug, 2010 10:10 am Oggetto: |
Prime impressioni d'uso di dpreview:
http://www.dpreview.com/news/1007/10072110panasonicdmclx5.asp#first
Interessante IMO il nuovo sensore (range dinamico piu' esteso), lo zoom piu' tuttofare e la possibilita' di usare il mirino della GF1.
Ora attendiamo il prezzo. _________________
ranton utente attivo
Inviato: Mer 21 Lug, 2010 11:13 am Oggetto: |
| capellimario ha scritto: | | resta però da vedere a quanto mm sale sopra i 2,8. Se è a 2 a 24 e a 40 è già a 3,3... |
| Citazione: | | Most significantly the lens range has been extended to offer a more flexible 24-90mm equivalent range while retaining a bright F2.0-3.3 maximum aperture range (it also matches the LX3's lens brightness over the shared focal length range). |
http://www.dpreview.com/news/1007/10072110panasonicdmclx5.asp _________________ https://www.flickr.com/photos/ranton/ |
Inviato: Mer 21 Lug, 2010 11:49 am Oggetto: |
vedremo il confronto tra questa e la nex-3.
una delle due la vorrei avere. |
Inviato: Mer 21 Lug, 2010 1:31 pm Oggetto: |
Adesso che mi son letto bene le caratteristiche devo dire che questa LX5 comincia a farmi gola.
Speriamo solo che lo zoom 24-90 equivalente mantenga la stessa qualità a tutta apertura e su tutto il range della zoomata che ha l'attuale 24-60.
Guardacaso, quando uso la pellicola (molto spesso) la terna di obiettivi che prediligo è 24-50-100.
Queta LX5 avrebbe proprio il range perfetto per me.
E se sono riusiti a migliorare ulterirmente il sensore...
Spero che abbiano mantenuto il rumore secco agli alti iso e non abbiano seguito la strada "dell'impasta tutto" degli altri produttori. |
